Need help on installing firmware Lg RH177
Discussion in 'Blu-ray & DVD Players & Recorders' started by dvdguy23, Jan 19, 2008.
  1. dvdguy23
    dvdguy23
    Feb 15, 2007
    111
    I want to install firmware 60911A on my LG Rh177.
    When I insert the disc a window comes up saying:
    Major update
    Press Rec button 3 times
    Open: other key.
    Now what does it mean by , open: other key???
    I dont want to mess this up and then have the firmware not installed properly making the machine un-usable.
    Please some advice needed!
  2. mray
    mray
    Feb 16, 2004
    2,772
    83
    London
    +234
    Hi.
    It just means pressing any other key will eject the disc. If you don't press the REC button three times, the firmware will not be installed.
  3. dvdguy23
    dvdguy23
    Feb 15, 2007
    111
    ok thanks!!
