** need help on choosing B&W speakers **
Discussion in 'Home Cinema Speakers' started by chonsasho, Mar 29, 2005.
  1. chonsasho
    chonsasho
    Hi, I am looking at two B&W speakers now, one of them is the DM601 S1 for $400(a pair), while the other one is the higher model of DM602 S3 for $700(a pair).
    Both are used speakers and broken in already, and no tax is needed since it's from my friend.
    Now is there a BIG difference in sound between these two speakers????? :confused:
    I owned a B&W 600 older series, and to be honest, I am very impressed with them for these past 8 years. So wanna get another set for my rear or centre.
    And yes, money is an issue for me here, so unless the DM602 S3 has a much better sounds over the 601, then I would consider that one.
    Any experts or audiophiles out there that can help me on this??
    Greatly appreciated. :D
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    Er.....I assume you are choosing between 601 and 602 S3's????
    Both sound lovely. You do get more bass out of the bigger 602's, but beware that they can boom in a small-to-medium sized room. They like a bit of space.
    If you can accomodate the bigger speakers, get 'em! ;)
