Need help on buying a DVD Recorder...
Discussion in 'Blu-ray & DVD Players & Recorders' started by Rock, Dec 26, 2006.
  1. Rock
    Rock
    Feb 24, 2004
    3
    See, what I'm really after is something that can record PAL-60 signals off my UK Xbox 360, and it seems that many DVD recorders simply aren't able to do this.
    And the big problem is, DVD recorder reviews rarely seem to cover this topic. 60hz just isn't the same as Pal 60, and if they do cover 60hz compatibility at all it's almost always just the NTSC part of it.
    In all, I'm looking for a good mix between price and performance. The better the picture it can record, the happier I'll be - but since it's just for recording gameplay footage, I don't really want to spend a fortune on it.
    Thanks for your time!
