Need help on bios and slayer installation
Discussion in 'Nintendo Forums' started by Tony19782, Jul 7, 2004.
  1. Tony19782
    Tony19782
    i installed bios in my samsung dvd in my xbox. i have a xecuter lite chip. when i put the bios cd in after the installation the system shut down. but when i turn it back on the tray opens and the green xbox ball appears like when the original xbox start. So how do i know when to install slayer and where can i get a slayer and how do i install slayer. Please help me, this is giving me a headache. Please.
  2. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,217
    Norwich
    +819
    Go to www.xbox-scene.com , head over to the forum and look in the Evox section of that forum, inside there is a sticky regarding Slayers, it tells you were to get it.
    You just boot the slayers disc up when you turn your xbox on, when it boots it will become obvious what you do next.
