Need help in connecting PS3 to Broadband
Discussion in 'Playstation Forums' started by covensky, May 1, 2007.
  1. covensky
    covensky
    Hello,
    I am trying to connect my PS3 to my PC (using ethernet cable), however am getting following error message in the PS3's Internet Connection settings test :
    Internet Connection failed
    "An error occured during communicatiob with the server"
    "This is a DNS Error 80710102".
    Hope this makes sense, any help would be much appreciated ( I have an Xbox360 connected to my Broadband, this works fine )
  2. Croftanator
    Croftanator
    Sep 7, 2005
    92
    11
    You have any joy in fixing this? I have the same problem.
    On the 360, I just change the MAC address to match my PC and it works no problems - but I can't see that option on PS3 :rolleyes:
  3. covensky
    covensky
    no, still no joy...I am almost ready to give up !
  4. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Why not just get a router. They aren't that expensive and make connecting easier and more convenient.
  5. doodles
    doodles
    Mar 20, 2006
    424
    +25
    what isp you with?
  6. covensky
    covensky
    I am with Bulldog Broadband
  7. covensky
    covensky
    Could anyone recommend a router, as it looks like my current setup is not going to work
  8. Moogle
    Moogle
    Aug 28, 2005
    13,751
    London
    +1,398
    Are you using a USB modem then ? I thought Bulldog provided a router.
    The thing with Bulldog is that they are not a normal ADSL provider like BT for example. They are an LLU service ( Local Loop Unbundling ). I think they may use ADSL2+. If they do then you will need to make sure the router you get is ADSL2+ compatible as not all of them are. Probably best to check with their customer service or better still other Bulldog users as to what router to get.
    Ofcourse I could be mistaken and they may be using normal ADSL in which case any ADSL router with modem will work. Like the Netgear DG834 (wired only ) or Netgear DG834G ( wireless and wired ). Those are pretty good routers and easy to set up.
