need help in buying dvd player! can you give me a hand?
S
Spacedog
My current shortlist is:
- Yamaha S540
- NAD T512
- Denon DVD700
- Marantz DV4400
and i'm looking for more quality (superb if possible) in audio than in video.
Can any of you give me any sugestions?
I'm anxious to get my new dvd player but i want to make shure i buy the right stuff.
Thankx a lot!
bonzobanana
Theres a Cambridge Azur model that sells for about £250 from richer sounds. Meant to be a very nice bit of kit. Certainly looks nice and will outperform the above models for audio cds (probably) and also do fine work for normal dvd replay.
S
Spacedog
yeah, that Cambridge really looks nice!! A bit out-of-budget for me, compared to the other models. But i guess it should be better...
thankx for the tip!
Sigismund
Hi.
I bought a Limit DVD900SE, which is tuned by Cyrus, from the Powerbuy forum. It is excellent as far as audio is concerned - with perfectly adequate video performance... I'm more than happy :)
Sigs
PS they also do an 800SE, which is also tuned by Cyrus but is a little cheaper ;)
Podcast: REL T/9x Subwoofer + Bowers & Wilkins PI7 Reviews, AV Shows in a Pandemic and more
