Need help getting MyIHome installed
ghouck
I have just upgraded my media server and now I can not get MyIHome to install. The installer says something like "This program can only be installed on versions of windows for the following architecture". I had it working on windows 10 which was an upgraded from W7 64 bit. That may have been an earlier version of MyIHome which I can not seem to find. I do have the Myihome folder from my old install but of course it will not run due to its registry dependencies. I believe an older version of MyIHome would work but have not been able to find one anywhere. If anyone knows where I can find an older version I would appreciate it.
I know MyIhome is an old app but it does work perfectly for my situation. I have PCH110s and the simple layout along with the way it allows me to shuffle a folder makes it work for me where nothing else does.
Thanks, Greg
