Quantcast
Need help from a Thomson 32WR25UG owner
bonzobanana
Basically I need the service menu values if anyone has them.
To get into the service menu you hold two buttons on the main set down while in standby mode for about 8 seconds. The buttons are vol- chan-
Once in can you look in the setup menu and just see if theres an option called 'Picture rotate' with a tick next to it. I've just got a set from skybuy which is the same set branded as Ferguson and I'm trying to find out if the set has this option removed if the thomson set has this option then it means the Ferguson set is loaded with restricted system software.
