hi i have 1 of these turning up on monday and want to get my wall mount acurately fitted but i need to know the size of the tv,bit confused cause the specs show these dimensions,is it the top 3 or bottom 3 that are the total dimensions or could an owner please measure the tv horizontally and vertically without stand many thanks Product weight : 23.2 kg Width (with base) : 964 mm Height (with base) : 512 mm Depth (with base) : 89 mm Weight incl. packaging : 31.2kg kg Box depth : 290 mm Box height : 813 mm Box width : 1160 mm Set depth : 120.5 mm Set height : 609 mm Set width : 1100 mm
