need help finding speakers
Discussion in 'Home Cinema Speakers' started by mind.stat3, Sep 11, 2007.
  1. mind.stat3
    mind.stat3
    Nov 14, 2006
    hey guys hows it going...
    i needed help finding some speakers....its not that simple...
    the thing is im looking for something that can connect to my TV and my Computer....or DVD..but Dvd is not very necessary...just mainly it should have a way i can connect my Tv to the speakers and my computer...
    like outputs for each of these...
    i was looking in argos and i saw these great speakers..but i dont think they connect with the tv...
    http://www.argos.co.uk/webapp/wcs/s...=-1&catalogId=1500000701&productId=1500050045
    check it out....
    or these ones were pretty good too
    http://www.argos.co.uk/webapp/wcs/s...=-1&catalogId=1500000701&productId=1500023119
    but this one is for the computer, mp3 player and all still no tv...
    please guys give me some advice as to what i need to buy....
    thanks...
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Your first option was the best. It has a Matrix surround option for 2 channel sources. It doesn't matter if your 2 channel source is an MP3 player or 2 channel out from a TV as long as the right leads are used. If you have more kit than it has inputs, a simple switch box will give you the flexibility you need.
  3. mind.stat3
    mind.stat3
    Nov 14, 2006
    thanks mate...but if its not too much trouble can you suggest exactly which switch box i need...bcos i was lookin on the net and i wasnt sure which one to choose....
    i would be greatful if you can recommend a good one for me...thanks
  4. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    I can't really suggest one because it has to suit your particular application, but the one I have was from Maplin here. You will need to see what leads are needed also.
