HTgnorant
Hi there.
I'm in the process of upgrading my 5.1 Mission speakers setup, with 4 addicional height front/rear speakers for atmos/auro3D.
It's an 8' (2,4meters) high ceiling and there is no possibility of in ceiling speakers.
Room is 20' x 13,8' (6,3 x 4,2 meters) dedicated HT.
Receiver: Marantz 7015
Use: streaming platforms only.
I,m thorne between this two models:
SVS Prime Elevation:
The question is, based on technical specs and the sound quality, wich should I choose?
- Rated bandwidth: 55 Hz-25 kHz (±3 dB)
- Nominal impedance: 8 ohms.
- Sensitivity: 87 dB (2.83V @ 1 meter full-space, 300-3kHz)
- Recommended amplifier power: 20-150 watts.
- Tweeter-to-woofer crossover: 2.5 kHz (12 dB/octave slopes)
- 1" Aluminum Dome tweeter
- 4,5" midrange drive
- Die cast aluminum enclosure (is this better? less weight maybe?)
- Frequency range: 86Hz - 25kHz (±3 dB)
- Nominal impedance: 6 ohms.
- Sensitivity: 86 dB (2.83V @ 1 meter)
- recomended amplifier power: 20 - 120W
- Crossover frequencies: 1,8kHz
- 28mm/1,1" soft dome tweeter
- 4,5" mid/woofer drive
