Need help connecting my PC to my PSP using a wireless pci card
Discussion in 'Playstation Forums' started by JonnyConcrete, May 15, 2005.
  1. JonnyConcrete
    JonnyConcrete
    May 14, 2005
    1,828
    Nottingham
    +190
    I am connected to the net via another PC using a LAN (ethernet cable) I have bought a wireless PCI card (NETGEAR WG311) so i can play multiplayer with xlink kai evolution 7 but i dont know how to set up the wireless card to transmit my connection to my PSP. HEEEEEEEEEEEEELP!!!!!!!!!! :lease:
  2. JonnyConcrete
    JonnyConcrete
    May 14, 2005
    1,828
    Nottingham
    +190
    the only time my pc recognizes my psp is when im on wipeouts host or join multiplayer screen
  3. jenic
    jenic
    Dec 10, 2004
    2,871
    83
    +179
    I think your PSP has to be version 1.0 and most have been upgraded by now.
  4. dr_loss
    dr_loss
    have you looked at the xlinkkai forums? they are much more helpflu on these kinds of things.....
    _________________________________
    www.ballofodd.co.uk - everything PSP
  5. JonnyConcrete
    JonnyConcrete
    May 14, 2005
    1,828
    Nottingham
    +190
    was looking all day yesterday cant find anything there that tells me how to set up my wifi pci card
  6. Ryderage
    Ryderage
    Feb 1, 2005
    72
    You need a Wireless access point. Not a Wireless Network card.
  7. JonnyConcrete
    JonnyConcrete
    May 14, 2005
    1,828
    Nottingham
    +190
    on this website www.ballofodd.co.uk it says Here is a brief guide and links to tell how to let you play psp with games over the internet and its all free.
    WARNING this doesnt work if you have a router!
    STEP : you will need
    A PC
    with a wi-fi card that is compatible (i bought 1 from the list)
    An internet connection (this requires that your wi-fi card is not used to connect you to a router which in turn connects you to the internet- cards cant do two things at once)
  8. dr_loss
    dr_loss
    that site is rubbish ;-) - actually its mine, nice to see someone is still looking, ive kind of been superseeded by the better sites now.
    i havent looked at xlinkkai for a while but from my previous endeavours i was sure that you could only use Kai with a wireless network card - you need that to connect to the psp and then another lan card in the same machine (not wireless) to connect to your internet connection. This is because the psp will only work with the wireless card in ad-hoc (computer to computer) mode and the other network card is used to pick up the connection to the outside world.
    so you can technically use it with an access point i.e laptop with wireless and wired network adapters with the latter plugged into the router/acces point.
    hope that helps....
  9. dr_loss
    dr_loss
    ah sorry, its looks like i have completely ignored your post and gone on a rant.
    i will look into this and see if i can find the answer (as i dont know)
    it is in ad-hoc mode and broadcasting a connection right?
  10. JonnyConcrete
    JonnyConcrete
    May 14, 2005
    1,828
    Nottingham
    +190
    kai diagnostics said my psp was configured properly but when i try and join the rooms my psp still says searching for multiplayer games. But I havnt been able to test it alot cos hardly any1 is playing.
    Do i need a wireless router to browse the net like it says on your website?
    Is an access point a wireless router?
