Need help choosing screen size Plz
Discussion in 'Projectors, Screens & Video Processors' started by chaank, Apr 16, 2005.
  1. chaank
    chaank
    Apr 10, 2005
    Cambridge
    I have just brought my first PJ "Benq PE5120" and plan converting the spare room into a Home Cinema. The amount of information, tips and tutorials on this forum is staggering i can't thank you all enough, it's really pointed me in the
    right direction. But i can't seem to get my head around just how big a screen i can have, and which size would cover 16.9, 4.3 ect.
    I'm planning on making my own screen and will be using " White Front Projection Screen Material".
    Projector Specification
    Aspect Ratio :
    16:9
    Projector Type :
    DLP
    Contrast Ratio :
    2000:1
    Resolution :
    854x480
    ANSI Lumen:
    1100
    Throw Ratio :
    60" @ 2m (60" @ 6.6ft)
    Inputs :
    Component
    DVI-I (with HDCP)
    S-Video
    Composite Video
    Weight :
    2.9kg
    Dimensions :
    262x99x216 mm
    Warranty :
    1yr loan support + 2yrs. RTB (90 Days on lamp)
    I hope this is enough info for you.......any help would be much appreciated.
    chaank.
  2. Malky1903
    Malky1903
    Jul 2, 2003
    1,908
    48
    Aberdeen
    +64
    Looking at the manual, a 4.2m throw distance will comfortably give you an 244 x 137cm image with a 45cm offset (distance from ceiling to PJ lens) for a 16:9 screen
    You will roughly get a 244 x 183cm image for a 4:3 screen with the same offset.
  3. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
