need help choosing a decent crt monitor
Discussion in 'Desktop & Laptop Computers Forum' started by matmum, Nov 28, 2004.
  1. matmum
    matmum
    Mar 23, 2003
    104
    16
    england
    hi
    i would like to upgrade my current crt monitor (formac pronitron 17/200) to something a bit larger and better quality but i am unsure what one to go for.
    i have a budget of only £200 and am really after one thats 19"-21" in size. it needs to work well with graphics and gaming.
    any suggestions would be greatly appreciated
    cheers
  2. Yandros
    Yandros
    Oct 13, 2003
    2,711
    +531
    I've always been a fan of the Diamondtron tubes, used by Iiyama and NEC/Mitsubishi. The Iiyama Visionmaster Pro 455 is roughly the right price for you at £222 inc VAT. I'd also consider the NEC Diamond Pro 930 SB which is usually regarded as the better of the two, but that might be over your budget (£276 inc VAT). Both 19" and to be honest probably represent the pinnacle of CRT technology, since all R&D is going into the LCD market now.
    Incidentally, I bought the 21" Iiyama recently for the office, and I actually still prefer clarity of the 19" version - the 21" has poorer focus IMO.
  3. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    I have both a 21'' Iiyama and a 19'' Trinitron. Both are superb however i'd say the Trinitron tube edges it. Pity there is little value in them as used monitors, they cost a small fortune when new :eek:
