SyStemDeMoN
This will be for my son. He is disabled he is in a wheelchair and only has limited movement in his hands and arms.
The problem we face is that this speaker needs to be easy to turn on and off, so via an app or alexa enabled. Or if it can have a on/off button that stays in the on position when switched off at the plug so I can connect it a plug socket connected to the iPad which we have for his fan.
His light in his room is controllable from his iPad and its been a god send for him.
He will use the speaker for his iPad and laptop.
Budget is upto £100 but I am willing to go over a bit for the right one.
