Need help buying TV/Video combi for a first timer
Discussion in 'TVs' started by abolakrami, Apr 29, 2003.
  1. abolakrami
    abolakrami
    Hi all,
    This is my first ever thread on this website so here goes
    Its my girlfriends b/day in 5 weeks and i am looking for to buy her a TV/Video combi about 14" to 18" which has sp/lp and two tuners, Im in the UK buy from UK websites or other UK businesses.
    Does anyone know where i can buy one from?
    Also what happens if you SP video in a video that plays LP will they both get screwed up
    Abs
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    SP/LP players can detrec the speed automaticaly!
    Try the usual places online
    Empiredirect
    qed-uk
    unbeatable
    etc etc etc
    Sony are good but expensive, aiwa cheap and ok Panasonic pretty good, stay away from really cheap no-name brands. LG do some nice combi sets and i think a 17" so do thomson have a look around and use pricerunner.co.uk to check for better deals
  3. abolakrami
    abolakrami
    OK so what happens if you put a SP video in to a video player that only plays LP?
    Will it mess up, i'm not quite sure.
  4. nathan_silly
    nathan_silly
    SP means normal speed
    LP (long-play) means half-speed, so you can fit ~320-360 mins onto a 180 min tape
    If you put a SP (ie rental video) into a VCR with LP, it'll work- as Long Play VCR's will obviously play normal speed tapes.
  5. Meebs
    Meebs
    Jan 28, 2003
    9
    Hertfordshire, UK
    2 tuners are essential. Buying this kit with one tuner is a mistake you only make once.....
  6. abolakrami
    abolakrami
    If SP videos can play in LP TV/combis what is the point in paying more for for TV/combis which play in SP.
    Surely would'nt it be better to buy a LP TV/combi which is cheaper.
    Or if i have misundestood previous replies what happens if the SP video goes in the LP video, can the LP video play the SP video if the TV/Combi only plays in LP
    Has anyone got anymore ideas where i can buy from the UK TV/Video combi which play SP and LP with twin tuners?
    Thanks for replying
  7. nathan_silly
    nathan_silly
    As above comment. Playing a SP (rented) tape in a VCR which supports LP will work.
    SP has better picture quality anyway, once you slow down the tape (LP) it'll be more fuzzy.
    I would buy seperate TV & VCR. Combo units are very unreliable, IMO.
