Need help buying new PC.
newgamer123
Hi I'm new too PC gaming and looking to get into it.
I'm currently buying the below from pcspecialist.co.uk
I just want to know how powerful is this PC? and can it run games like MGS5 etc at full spec at 4K? Can I also use it to watch full 4K videos and edit them? and how future proof is it?
Also will it have an Ethernet port because I chose a wireless card and of course is it worth £948, and how much would it cost if I built it myself?
Thanks!
Case : COOLERMASTER ELITE 311 BLUE CASE
Processor (CPU) : Intel® Core™i7 Quad Core Processor i7-6700k (4.0GHz) 8MB Cache
Motherboard : ASUS® Z170 PRO GAMING: ATX, LG1151, USB 3.1, SATA 6GBs
Memory (RAM) : 16GB KINGSTON HYPER-X FURY DDR4 2133MHz (2 x 8GB)
Graphics Card : 2GB NVIDIA GEFORCE GTX 750 Ti - VGA, DVI, HDMI - 3D Vision Ready
1st Hard Disk - 2TB 3.5" SATA-III 6GB/s HDD 7200RPM 64MB CACHE
1st DVD/BLU-RAY Drive : 16x BLU-RAY WRITER DRIVE, 16x DVD ±R/±RW & CYBERLINK SOFTWARE
Memory Card Reader : INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply : CORSAIR 350W VS SERIES™ VS-350 POWER SUPPLY
Processor Cooling : Super Quiet Titan DragonFly Heatpipe Intel CPU Cooler (£19)
Thermal Paste : ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND (£9)
Extra Case Fans - 1x 120mm Apache Black Quiet Fan (fitted to extract from rear/roof) (£14)
Sound Card : ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
Wireless/Wired Networking : WIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD (£12)
USB Options : MIN. 2 x USB 3.0 & 4 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Power Cable : 1 x 1 Metre UK Power Cable (Kettle Lead)
Operating System : Genuine Windows 10 Home 64 Bit - inc DVD & Licence (£79)
Windows 10 Upgrade : FREE Upgrade to Windows 10 with all Windows 7 & Windows 8.1 Purchases*
Office Software : NO OFFICE SOFTWARE
Anti-Virus : NO ANTI-VIRUS SOFTWARE
Warranty : 3 Year Standard Warranty (1 Month Collect & Return, 1 Year Parts, 3 Year Labour)
Delivery : STANDARD INSURED DELIVERY TO UK MAINLAND (MON-FRI)
Build Time : Standard Build - Approximately 7 to 9 working days
Quantity : 1
Price: £948.00
Greg Hook
Moderator & Reviewer
Unfortunately not. That graphics card is nowhere near powerful enough.
I'm afraid for 4K full spec gaming you are probably looking at spending £2K on a PC, at least.
aslird
Please do not buy that PC. You are pairing a powerful CPU with a low end graphics card, and a very low spec PSU - the equivalent of putting a noisy exhaust on a Vauxhall Nova.
If you want to play full spec 4k gaming (that is high/ultra graphics at 60 fps), then you need to have 2 980 gfx cards, which are £500 each, and at least a 800W PSU.
newgamer123
Thanks for the reply guys.
Ok so I just changed the following:
Processor (CPU) - Intel® Core™i5 Quad Core Processor i5-6600K (3.5GHz) 6MB Cache
Graphics Card -
4GB NVIDIA GEFORCE GTX 960 - DVI, HDMI, 3 DP - 3D Vision Ready
Free Item: FREE METAL GEAR SOLID game with select GTX 9 Series GPUs! -Subject to T&Cs
Power Supply - CORSAIR 450W VS SERIES™ VS-450 POWER SUPPLY
Price: £952.00
is that any better? the graphics card come with MGS5!
if i wont be able to run it at 4K can I at least run it at 1080p?
Thanks.
Greg Hook
Do you really need a Blu-Ray writer drive? Also could you trim your HDD down to 1TB and maybe squeeze a SSD in the mix?
Greg Hook
Great suggestion.
There's no need for 16GB RAM either, so have a look at that thread linked by Chalky.
newgamer123
Thanks again for the replies.
Based on the post by Cha1ky I have come up with the below as its the closet:
Is that any better?
If it’s not too much trouble can you guys build me a PC on pcspecialist.co.uk with the best possible performance for around a £1000? I would appreciate it a lot because quite frankly I have no idea what I’m doing.
Thanks.
Case - COOLERMASTER ELITE 311 BLUE CASE
Processor (CPU) - Intel® Core™i7 Quad Core Processor i7-6700k (4.0GHz) 8MB Cache
Motherboard - Gigabyte Z170XP-SLI: ATX, LG1151, USB 3.1, SATA 6GBs
Memory (RAM) - 16GB KINGSTON HYPER-X FURY DDR4 2133MHz (2 x 8GB)
Graphics Card - 4GB NVIDIA GEFORCE GTX 970 - 2 DVI, 1 HDMI, 1 DP - 3D Vision Ready
1st DVD/BLU-RAY Drive - 24x DUAL LAYER DVD WRITER ±R/±RW/RAM
Memory Card Reader - INTERNAL 52 IN 1 CARD READER (XD, MS, CF, SD, etc) + 1 x USB 2.0 PORT
Power Supply - CORSAIR 550W VS SERIES™ VS-550 POWER SUPPLY
Processor Cooling - Corsair H55 Hydro Series High Performance CPU Cooler (£39)
Thermal Paste - ARCTIC MX-4 EXTREME THERMAL CONDUCTIVITY COMPOUND (£9)
Extra Case Fans - 1x 120mm Black Case Fan (configured to extract from rear/roof) (£5)
Sound Card - ONBOARD 6 CHANNEL (5.1) HIGH DEF AUDIO (AS STANDARD)
Wireless/Wired Networking - WIRELESS 802.11N 300Mbps/2.4GHz PCI CARD (£16)
USB Options - MIN. 2 x USB 3.0 & 4 x USB 2.0 PORTS @ BACK PANEL + MIN. 2 FRONT PORTS
Power Cable - 1 x 1 Metre UK Power Cable (Kettle Lead)
Operating System - Genuine Windows 10 Home 64 Bit - inc DVD & Licence (£79)
Windows 10 Upgrade - FREE Upgrade to Windows 10 with all Windows 7 & Windows 8.1 Purchases*
Office Software - NO OFFICE SOFTWARE
Anti-Virus - NO ANTI-VIRUS SOFTWARE
Warranty - 3 Year Standard Warranty (1 Month Collect & Return, 1 Year Parts, 3 Year Labour)
Delivery - STANDARD INSURED DELIVERY TO UK MAINLAND (MON-FRI)
Build Time - Standard Build - Approximately 7 to 9 working days
£1,070.00 inc VAT and Delivery.
Cha1ky
Does it have to be through PC Specialist or can you buy from elsewhere?
Would you be willing to build yourself or need a company to do it for you?
Joe Pineapples
Just to chip in. Change that case. Its a bit of a cheapo, (not even front USB 3.0) to put all that nice gear into. The NZXT S340 MID TOWER GAMING CASE (on their page) or even pushing to the Fractal R5 would be much better choices (better airflow, future proofing and generally better designs). Just check the external physical dimensions, if that is a factor.
newgamer123
I'd need a company to build it for me as I have no idea how to do it myself. I'd appreciate it if you could recommended a better site.
@Joe Pineapples What benefit would I get from using that case apart from it being better looking? Because I’m not too fussed about the looks to be honest.
Cha1ky
You looking around a budget of £1100 max then?
You do pay a premium for having a company build it for you mind mate. Prob around £100 on a £1000 build. It's not too hard to do yourself and we would always say to do that hear but I understand if you don't want to as not everyone wants to do that.
Joe Pineapples
Both those cases I listed should be quieter, cooler running (helping the 970) and offer more comfortable room for expansion if you wanted to add anything later. Front USB 3.0 ports also come in handy.
newgamer123
@Joe Pineapples @Cha1ky
Thanks for the reply guys. Based on your feedback I've come up with the below specs.
Will I be able to play current games like GTA5 / MGS5 at 1080p 60fps?
And is it worth the money or am I being ripped off?
Thanks.
Case - STYLISH BLACK/SILVER TRIDENT CASE + 2 FRONT USB
Motherboard - ASUS® Z170 PRO GAMING: ATX, LG1151, USB 3.1, SATA 6GBs
1st Hard Disk - 240GB KINGSTON V300 SSD, SATA 6 Gb (450MB/R, 450MB/W)
2nd Hard Disk - 2TB 3.5" SATA-III 6GB/s HDD 7200RPM 64MB CACHE
Processor Cooling - Super Quiet Titan DragonFly Heatpipe Intel CPU Cooler (£19)
Wireless/Wired Networking - WIRELESS 802.11N 300Mbps/2.4GHz PCI-E CARD (£12)
Quantity - 1
£1,139.00 inc VAT and Delivery.
moonbeam120
You could try these components. I used Partpicker. If you look around you could find some of the components cheaper. Only thing is you would have to build it yourself. Tbh it's easy done. Just watch some youtube build videos and if you have any problems I'm sure I - and many on this forum - will be happy to help and give advice. The important thing is to read the documentation and plan ahead. Patience is key. This would be a really kicking rig. Not GTX980Ti kicking but close - for around £300 less.
CPU
Intel Core i7-6700K 4.0GHz Quad-Core Processor
£289.99 Buy
CPU Cooler
Corsair H55 57.0 CFM Liquid CPU Cooler
£49.99 Buy
Motherboard
Asus Z170 PRO GAMING ATX LGA1151 Motherboard
£116.45 Buy
Memory
Corsair Vengeance LPX 16GB (4 x 4GB) DDR4-2133 Memory
£93.55 Buy
Storage
Samsung 850 EVO-Series 250GB 2.5" Solid State Drive
£73.00 Buy
Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive
£51.19 Buy
Video Card
Gigabyte GeForce GTX 970 4GB Video Card
£229.99 Buy
Case
Fractal Design FD-CA-CORE-3300-BL ATX Mid Tower Case
£40.22 Buy
Power Supply
EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply
£69.95 Buy
Optical Drive
Samsung SH-224DB/BEBE DVD/CD Writer
£9.36 Buy
Operating System
Microsoft Windows 7 Home Premium SP1 OEM (64-bit)
£67.95 Buy
Total: £1091.64
Joe Pineapples
If you still prefer the idea of a pre-built system, I'd suggest looking at his one...
CCL Elite Eagle IV Gaming PC - - CCL Computers
CONS
Not Skylake
Not bluray drive
costs a bit more after adding Win10
PROS
Better suited case (1x120 fan intake, 1x120 exhaust, option for 2nd intake), USB 3.0
Better cpu cooler
Better SSD
3yrs collect & return warranty
Hope this helps.
newgamer123
CONS
Not Skylake
Not bluray drive
PROS
Better cpu cooler
Better SSD
Hope this helps.
Thanks I ended up buying that PC, with Windows 10 pro and a better DVD drive for £1197.07
Thanks for the help every one. :)
Sinzer
Welcome to the club of the ever-growing STEAM Library!
May your games be cheap and your purchases impulsive, and forgive Lord Gaben as he steals your daily bread with Midweek Madness specials!
RonMort
Hi im new-ish to pc gaming and need help as im not to sure if all these components together will be compatible, im not to sure if the psu and process cooler are good enough? Also do i need the windows 10 ... £79 seems rather steep lol and would you recommend any other websites rather than pc specialist?
Thanks!
Case
PCS ALPHA TRION 7622B BLACK CASE
Processor (CPU)
Motherboard
Gigabyte Z170X Gaming 3 ATX, LG1151, USB 3.1, SATA 6GBs
Memory (RAM)
16GB HyperX FURY DDR4 2133MHz (2 x 8GB)
Graphics Card
4GB NVIDIA GEFORCE GTX 970 - 2 x DVI, HDMI, DP - GeForce GTX VR Ready!
1st Hard Disk
1TB SATA-III 3.5" HDD, 6GB/s, 7200RPM, 32MB CACHE
Power Supply
Processor Cooling
Thermal Paste
STANDARD THERMAL PASTE FOR SUFFICIENT COOLING
Sound Card
WIRELESS 802.11 AC1300 867Mbps/5GHz, 400Mbps/2.4GHz PCI-E CARD (£29)
USB Options
2 PORT (2 x TYPE A) USB 3.0 PCI-E CARD + STANDARD USB PORTS
Power Cable
Operating System
Operating System Language
United Kingdom - English Language
Office Software
FREE 30 Day Trial of Microsoft® Office® 365
Anti-Virus
BullGuard™ Internet Security - Free 90 Day License inc. Gamer Mode
Monitor
IIYAMA GB2788HS-B1 27" Freesync Gaming Monitor (£256)
Warranty
Greg Hook
What's that all come to?
Latest News
Rumour: Samsung even closer to OLED TVs in 2022?
  • By Andy Bassett
  • Published
Audio-Technica launches ATH-SQ1TW true wireless earphones
  • By Andy Bassett
  • Published
What's new on UK streaming services for December 2021
  • By Andy Bassett
  • Published
Best Projectors of 2021 - Editor's Choice Awards
  • By Steve Withers
  • Published
Black Friday 2021: What you need to know
  • By Andy Bassett
  • Published
