Question Need help buying a multi zone sound system for medium sized bar
Discussion in 'Hi-Fi Stereo Systems & Separates' started by The Chosen, Jul 14, 2018.
  1. The Chosen
    The Chosen
    Nov 23, 2006
    16
    I’m looking to buy a multi zone sound system for a medium size clubhouse. For the main part, all speakers will be outputting from the same zone, but in a few situations, our clubhouse will be split into with a prop up wall, so will require two zones so that I can output different music/sound. The room is rather square, so I’d anticipate 6 speakers would probably be enough.
    I’ve got a budget of about £1000.
    Any recommendations welcome.
  2. muljao
    muljao
    Jan 24, 2017
    2,072
    116
    Ireland
    +755
    You'll need to give more info
    Will your music be on cd/streamed from Spotify etc and how big are the rooms
    1000 is a good budget for a stereo set up in a house but very poor for a bar
