Hi there, thanks for the reply
These were 3 I was previously looking at. I know you said there's not much point in comparing but which would you say is best for gaming/streaming and why? They're pretty similar in price.
Picture quality: 60 Hz; HDR: HDR10 / Hybrid Log-Gamma (HLG); Catch-up TV & streaming; Freeview HD with Freeview Play / Freesat HD; HDMI 1.4 x 3
www.currys.co.uk
Picture quality: 1000 PQI; HDR: HDR10+; Catch-up TV & streaming; TV PLUS; HDMI 2.0a x 2
www.currys.co.uk
www.currys.co.uk
I've been (casually) looking at replacing a couple of older, smaller kitchen and bedroom LCDs in my place for a while now and those Samsung and LG models you posted really do seem to be the 'best of a bad lot' at the moment.
FWIW, the Samsung doesn't have Bluetooth, Freeview Play or a Freesat tuner whereas the LG models do (as far as I can tell from the spec tables at least). I've also seen reports of adverts on the Samsung OS/guide and wi-fi issues. The LG sets aren't perfect though - their cheaper sets can sometimes suffer from a lack of memory issue when running apps, requiring the apps to be restarted or a reboot. I've seen this happen on my partner's 24" LG LCD which she bought last year.
If you go for the LG, the choice between the 720p LM637B and 1080p LM6370 will probably depend on the content you'll be watching - the only reason I can think of for choosing the 720p model is if you watch a lot of SD Freeview or DVDs but if you're mostly gaming and streaming, then presumably the LM6370 makes the most sense. If the missing features on the Samsung aren't an issue and you have it connected via ethernet, then the Samsung may also still be in the running.
Whichever you choose, I would try and buy from a retailer you can easily return it to in the event of problems and/or if you're not happy. Richer Sounds are still selling the 32" LM6300, so you'd get a 6 year warranty when compared to the 1 year if you buy the LM6370 from Currys.
The jury is still out for me - I'm not desperate for a new set, so it'll probably just come down to the price and/or warranty provided.
