Question Need help building a Gaming Computer
ThermicLine
After about 3 years of using a premade Alienware computer, I want to build my own gaming computer. The Alienware I have now is slow, laggy, cannot load games at 60 fps, and often can't even load a number of games that are in my Steam library without a couple of extra tries. Is there any advice anyone can give as to where I should start to build my gaming computer? Any place to check for prices of parts, quality, etc? Thanks in advance.
richardb70
If I were you, I'd come up with a budget and a rough list of what you need (monitor? OS? etc), as well as your target gaming resolution (1080p / 1440p / 4k).
Then check the sticky thread at the top of this forum for ideas, use a site like part picker or scan and put a shopping list together. Post this list back and the experts here will have a look :)
alphaomega16
Only 3 years old ?
Have you tried a clean install in that 3 years, maybe after 3 years the OS is a bit cluttered and slowing down.
What spec is your current machine ?
Dave2
As per the other two we need more detail.
Budget e.g what you have to spend
What is your current specs.
