mike7
The stand for the C1 and C2 is black/grey. The photography of it makes its semi reflective surface appear to be silver, which, in reality, it certainly isn't.I'd be keen on the LGC1 65" to get a 65" but for the stand. Same with the C2. I wish these were very dark grey or black. Can't stand the silver stands.
The only problem you might encounter with stand of the C1, and I suspect the C2, is that, in common with other recent models it means the TV sits very low on your furniture. The distance leaves very little space for a soundbar placed directly in front of it, unless you can find an extremely narrow one or are not bothered if the bar partly shields the lowest part of the screen. There are several discussions, and solutions, already on the Forum. I tailor-made a painted wood plinth/base to raise the TV slightly so I could use a Sonus Beam soundbar without obstructing the lower part of the screen.
