Need Help about SANYO PLV30 service mode
Discussion in 'Projectors, Screens & Video Processors' started by bose, Feb 6, 2002.
  1. bose
    bose
    I'm a newbie in this forum and about front projector.Last week I decided to buy a Sanyo plv30 and few day ago I go into the service mode
    (by press MENU button and NORMAL button at the same time and hold it about 15 seconds) and adjusted the values with a datasheet that my saleman told me it's a optimum values.
    BUT before doing that I FORGOT TO COPY ALL PREVIOUS VALUE!!! after the adjustment, the picture quality is much worse than before and I want to go back to pevious value of service mode
    BUT I can't remember all value.Now I'm very confused about adjusting every value to get the picture quality as good as i've got.
    So can anyone tell me about the value in your SERVICE MODE ,espescially the values of Menu NO.1 to 30
    THANKS for your help..............
    bose
    [email protected]
  2. z5461313
    z5461313
    Sep 18, 2001
    1,713
    +265
    Hello
    Which values did you change - was it needed to change them
  3. bose
    bose
    I can't remember the exact value i've change,just remember that it's between value NO.1 to 30.Before changing I set up with Video Essential and the projector can't display the blacker bar in test pattern.So I guess that the pre-set value may not be correct and then I changed it.But it's my fault that i forgot to copy the value.
    So if not bother you (or anyone own this pj)so much.
    Can you please tell me the value NO.1 to 30 and 272,273,274
    bose
  4. bose
    bose
    because now I still can't setup to get optimum picture quality,and my dealer just said that they can't help me except send projector to them for checking the detail
    bose
    [email protected]
  5. z5461313
    z5461313
    Sep 18, 2001
    1,713
    +265
    Sorry I don't have my projector with me - work away
    What you can do is phone owl video systems who distribute the projector 01825 766123 and ask for technical support
  6. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    Or post on the owl forum and hope that for a useful reply!
    I have the sanyo.......i would be very happy to check it for youi.....but since i cant easily get mine sent back.....im sh** scared of going into the service menu!
    If i pluck up the courage i will tell you what i find!
    ad
  7. bose
    bose
    Thanks for your reply
    and can you tell me the url of owl forum?, i'll go there for any information
    bose
  8. AlfaKhan
    AlfaKhan
    Aug 7, 2001
    250
    Cascais, Portugal
    +6
    Hi Bose!
    Good news and bad news.
    First the bad: From other forums (...and from other LCD projector names and models) I understand that knowing these numbers for a particular projector does not necessarily mean that they can be used on another projector.
    The good news are, I can provide you with my projector numbers:
    0/14, 1/14, 2/3, 3/12, 4/5, 5/(skipped), 6/5, 7/(skipped), 8/5, 9/27, 10/27, 11/27, 12/36, 13/13, 14/12, 15/70, 16/71, 17/65, 18/30, 19/12, 20/12, 21/12, 22/0, 23/1, 24/143, 25/4, 26/57, 27/57, 28/57, 29/0
    30- When Y,Pb,Pr selected: 128
    30- When S-Video selected: 129
    272/96, 273/115, 274/122
    Hope it helps.
    HB
  9. jason t
    jason t
    Mar 4, 2001
    1,709
    48
    kent
    +38
    afakhan
    where did you get all these numbers??
    when i went into my service menu i just got two sets of numbers!!!!
    which was 0 on the left and 6 on right
    jason
  10. AlfaKhan
    AlfaKhan
    Aug 7, 2001
    250
    Cascais, Portugal
    +6
    Hi Jason,
    The number on the left is the parameter (don't ask me what they are, since I do not have a guide). The numbers on the right are the values for that parameter.
    Toggle between parameters (left window) using the UP and DOWN keys on the remote or the projector itself.
    DO NOT TOGGLE THE VALUES on the right (or, if you do, at least take a note of the number so you can return to the original setting).
    If your value for the first parameter (0) is 6, that proves there are different factory settings between projectors, since mine is 14.
    I would love to get my hands on a proper parameter list. Can anyone help?
    HB
  11. bose
    bose
    Thanks AfaKhan
    Did you tell me that the value on a plv30 can't use with another one ?and can you tell me the url link of the other forum about this pj
    I'll try your value to see any better difference
    I've the datasheet that describe the detail of every parameter.I'll scan it and post on a new thread, may be on monday
    And still wait for another owner of plv30 comment
    bose
  12. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    the forum i refer to is on this site under manufacturers forums.....Owl......I'm sure if you post there or get the email addresses of one of the owl guys they will help if possible.
    Ad
