Need headphone purchasing assistance, please help!
Discussion in 'Headphones, Earphones & Portable Music' started by kidkoala, Oct 19, 2005.
  1. kidkoala
    kidkoala
    I've finally decided to take the plunge and buy a semiexpensive set of headphones (around $100), but the problem is I don't know exactly what I want.
    I listen to MP3's on the go a lot and so I thought so earbuds would be good. This led me to the Shure E2c's, which I can get for around $70 I believe. They are in-ear canal headphones, and so entirely plug your ear canal so that you do not hear any outside noise. They are also not friendly to being taken out and put back in a lot, due to the tight fit that they require, which means they take time to insert properly. However, I figure these would be pretty good for when I'm on the go, and also when I am at home, relaxing.
    My other option I was considering is getting some inexpensive Sony MDR-EX71SL earbuds ($25 on Amazon, and still with good sound quality) for when I am traveling, and then investing in a nice set of standard cans (maybe Grado's or Sennheiser's). If I did go with this method, what is a good set of normal, full-sized headphones in the $~80 range? There was also a set of Sony's I was considering, but I really know nothing about this kind of thing, only what the reviews I've read tell me. I would want something that provided good sound for all kinds of music, mostly rock I guess, and also looked cool.
    Which of these two options sounds best to you guys? Thanks for any kind of input.
  2. sirlukas
    sirlukas
    Sep 3, 2005
    908
    Woodley
    +91
    My types:
    Koss The Plug, Sennheiser PX100, Koss Porta Pro
    Grado SR60 or 80, Sennheiser HD 580 or so.
    You should be fine with money.
  3. andyrich
    andyrich
    Aug 17, 2005
    28
    go for the E2c's using the foam sleeves koss porta pro's are good but not as good as E2c's
  4. Reano
    Reano
    Jan 6, 2003
    873
    28
    Telford, UK
    +47
    Have you looked on ebay to see if you can get the e3c (unused of course) for £100 or less
  5. flamejob
    flamejob
    i picked up my e3c's for 70 quid includin postage.
