Need HDTV under £500 - All features etc
Discussion in 'LCD & LED LCD TVs Forum' started by salami1212, Mar 23, 2006.
Tags:
  1. salami1212
    salami1212
    Well, I know nothing much about hdtv, but i need a hdtv for under £500. It will be used for pc use aswell as tv. I want it to be at least 23" and I want it to have all the hd features like hdmi and hdcp. I dont know what they are but they are meant to make the picture look better right? Also, I will be gettin freeview, so if you could tell me what connectors i would need for that to make it look good. Also would i need a new graphics card?
    PS: i also heard about new technology coming out which makes lcds not have a response time or new gpus which support hdtv? should i wait for them?
  2. Vallyboy
    Vallyboy
    No need to re-post your original post, just say "Bump" on the original thread, or add some more info. 'Tis Netiquette.:)
    With regards to "everything for less than £500" your best bet is to wade through the Freeman's threads where you will see that you can get an all singing all dancing 26" Samsung for £450.:D
    As for waiting...you will always find a better set due to come out, and you will pay a premium for the privilege.:D
