brad123
Im after a hack for a friends DVD player. Its the Goodmans GDVD 124 player.
Anyone done a hack thats been succesful for this player.
just found this hack, anyone know if it works
1. Open the drive tray
2. Press the buttons 7 and 4 on your remote control in order, one at a time
Note: If the above doesn't work, you may have to enter the digits 7 and 7 instead
3. Press the Enter button on your remote control
4. A hidden menu will appear where you can scroll down to Country Code and using the Select button, choose any region between 1 and 6, or select 13 for region free.
5. Press the Enter button on your remote control
6. Press Return to exit the menu
