Need Hack for Daewoo DF-N71N Combi
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by spotter0005, Apr 30, 2005.
  1. spotter0005
    spotter0005
    Looking for a hack for a Daewoo DF-N71N.
    Have tried all of the below and none have worked.
    My Model Information
    Version FN300BAAVL
    BUILD 3.2.9
    SOFTWARE 3.1.1
    NAVIGATION 2.0.0
    LOADER BDR-G2DC
    H :lease: elp?
    REGION FREE DVD REGION FREE METHODS FOR : DAEWOO
    MODEL(S) : METHOD : CONFIRMED? DVG-8300SE 1.- Turn On.
    2.- Press Open.
    3.- Press 1 3 7 9 and the number of the zone that you want to use between 1 and 6.
    4.- Now enter the movie and press play.
    5.- If you want to watch other movie with other zone, just do the same with that zone number.
    MODEL(S) : METHOD : CONFIRMED? DQD-2112D DVD-260D DQD-6112D DV6T821N
    1. Press the 7 button on your remote control.
    2. Press the 7 button on your remote control.
    3. Press the Play button on your remote control.
    4. You should now be in a secret menu where you can change the country code to 1 for region 1, 2 for region 2 and so on, or 0 for multi-region playback.
    5. Press the Setup button on your remote control. If playback is now in black and white, do the following.
    1. Press the Setup button on your remote control.
    2. Select Video setup.
    3. Select Type TV.
    4. Select the PAL option.
    Try this if the above method doesn't work:
    1. Open DVD tray.
    2. Entre 0520 using remote.
    3. Press keys in this order: UP, DOWN, LEFT, RIGHT.
    4. Enter region code, 0 for complete code free.
    5. Close DVD tray.
    MODEL(S) : METHOD : CONFIRMED? DVD-5900
    1. Turn Power On
    2. Eject Disc Tray
    3. Using the remote control, key in the following: 8, 5, 6, 1.
    4. You can then select the region number or 0 for region-free. Yes
    MODEL(S) : METHOD : CONFIRMED? DQD200 DHC2200 DHC2300
    1. Press SETUP, TITLE, STEP, NEXT on the remote control
    2. Select the region desired or BYPASS for region-free, using the up and down keys on the remote control.
    3. SAVE and then EXIT the menu.
    MODEL(S) : METHOD : CONFIRMED? DVG-3000N
    1. Turn the player on.
    2. Press Open\Close, to open the tray.
    3. Press Setup on the remote control.
    4. Press Play.
    5. Choose TV Type in the menu with the remote control.
    6. Press Stop on the player's front panel (NOT from the remote).
    7. Press |< (Prev) on the players front panel.
    8. Press >| (Next) on the players front panel.
    9. The Region ID menu should come up.
    10. Select the desired Region (with remote control)or Bypass for region free.
    11. When you have selected the desired region press Play.
    12. Now press Setup on the remote control. Yes
    MODEL(S) : METHOD : CONFIRMED? DVG-4000S
    4. Press Play.
    7. Press the players remote control.
    8. Press >| (Next) on the players remote control.
    MODEL(S) : METHOD : CONFIRMED? 3700 5800
    1. Press Open/Close, Setup on the remote control.
    2. Press the number of the region you want, or 9 for region free.
    3. Press 3, 0, 1, 0, Step, Shuffle, Next on the remote control.
    To check the region, you will need to see the hidden menu:
    1. Press Open/Close, Setup, Shuffle, Step, Next on the remote control.
    2. Scroll down to Debug, which shows the region number.
    For Macrovision firmware patches, go to:
    http://www.dvd-wizards.com/darrenk/daewoo_dvd5700/dvd-5700patch.htm
    These are also on the CD version of the site - check out the shop.
    Note 5700 player does not work with this method, even though you can appear to change the region number. Yes
    MODEL(S) : METHOD : CONFIRMED? DS 2500N
    1. Turn on the player.
    2. Open the player's tray and leave it with no disc in it.
    4. From the menu, choose Parental Control using the arrows on the remote control.
    5. Choose Defaults, the highlight Reset, but do not press OK at this stage.
    6. As Reset is still highlighted, enter the 5, 2, 7, followed by the region required, or use 0 for region free.
    7. You should see REGION: plus the code entered on screen.
    8. Press OK on the remote control.
    9. A Password Verify screen should then appear.
    10. Enter 0, 0, 0, 0 using the remote, followed by OK.
    11. Press Setup on the remote control.
    MODEL(S) : METHOD : CONFIRMED? DVG-6000D
    1. Make sure there is no disc in the player and the tray is closed.
    2. Using the remote control, key in the following: Open, Setup, Stop, Previous, Next.
    3. A hidden menu will appear, enabling you to select the region number. Yes
    MODEL(S) : METHOD : CONFIRMED? DV-115
    1. Remove any discs in the machine.
    2. Press the Open/Close button on the front of your DVD (Open lid).
    3. On the Remote Control key in 8, 9, 2, 6.
    4. Wait for five seconds.
    5. Press 0 on the Remote Control.
    6. Wait for 15 seconds.
    7. Press the Open/Close button on the front of your DVD (Close lid). Yes
    MODEL(S) : METHOD : CONFIRMED? DVD-5700
    1. Key in the following on the remote control: Open/Close (tray open), Setup, Shuffle, Step, Next.
    2. You should be able to see the secret menu and scroll down to DEBUG and the list shows from 1-9 (which is regions). Option 9 is region free/bypass.
    3. By default 1 is ticked and will not able to change permanently.
    MODEL(S) : METHOD : CONFIRMED? DHC-8000K
    1. Using the remote control, key in the following: Stop, 4, 4, 0, 8.
    2. For Region 1, press the 1 button on your remote control, for Region two press 2, and so on, or press 0 for multi-region playback.
    3. The onscreen display should indicate the changed region. If nothing happens repeat the above steps but press the indicated buttons in a faster sequence.
    MODEL(S) : METHOD : CONFIRMED? DVD8000F
    1. Using the remote control, key in the following: Setup, Mute, Stop, Zoom. Yes
    MODEL(S) : METHOD : CONFIRMED? DVD-S150, S250 9000S5, DVD-5900M.
    1. Power On DVD player.
    2. Press Setup.
    3. Press 1,3,6,9,8,8,8 and 8.
    4. A new button called Version will now appear in the Setup window.
    5. Press Down until you come to Version.
    6. Press Play.
    7. Press Up or Down to select the required region. Choices are from 0 to 6.
    8. Press Setup.
    For the 9000S5, use 13798888 in step 3.
    for 150, but you may have to try and try again! Yes, for 9000S5.
    MODEL(S) : METHOD : CONFIRMED? 5000N
    1. Turn on the dvd player without dvd
    2. Press setup
    3. Press stop
    4. Press rewind
    5. Press forward
    6. You should now be in the page of the factory where you can choose the region. Yes
    MODEL(S) : METHOD : CONFIRMED? 5800D
    1. Make sure there is no disc in the drive.
    2. Using the remote control, key in the following: Setup, Stop, Skip Back, Skip Forward, followed by the region number or Bypass for region free.
    3. Press enter (yellow play button).
    4. Press setup. Yes
    MODEL(S) : METHOD : CONFIRMED? DQD-2100 DQD-2113 DQD-6113D DVD-363 DVD-323
    1. Press the Open button on your remote control to open the disc tray
    2. Using your remote control, press the buttons 0, 5, 2 and 0, in order, one at a time
    3. Press the Up button on your remote control
    4. Press the Down button on your remote control
    5. Press the Left button on your remote control
    6. Press the Right button on your remote control
    7. You should now be able to change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
    Player can be locked again using same sequence, only REGION LOCKED-message appears.
    Does not seem to work for newer versions of 2100D, but works for players from 2002...
    MODEL(S) : METHOD : CONFIRMED? TPSL-102
    1. Using the remote control, key in Setup, +10, Prev, Next.
    2. A screen will appear which will show you that the DVD player is in Region 1.
    3. Use the left and right arrows to select the region you want to play.
    4. When you have selected the region press the Setup button to exit.
    5. Power off the DVD player, when you power on the DVD player it will select the new Region. Yes
    MODEL(S) : METHOD : CONFIRMED? DV6T811N
    1. Turn on player.
    2. Open tray.
    3. On remote - press 0520.
    4. On remote - press up(^) down(v) left(<) right(>).
    5. The above keys are around the setup button.
    6. Region free message appears in the top left corner.
    Note: To lock region again, repeat sequence.
    MODEL(S) : METHOD : CONFIRMED? 9000N
    1. Insert foreign DVD disk
    2. Press: setup, stop, I<<, >>I, then select region required.
    3. Press: setup, set up, then exit from set up menu.
    4. Then press Play.
    5. Then press p/n button to select relevant TV type (not auto)
    Note that player will revert to default settings when you turn power off. Yes
    Region code hack posted by Robert paul, May 02 2003:
    When the dvd player is on with no disk
    press setup menu
    than scroll to perferences
    enter pasword "0000"
    than enter 5425
    press 5425 again
    choose region "all"
    than press setup menu and you're done
    this code whas given to me from a guy who works at daewoo
    Region code hack posted by Bart van Beek, November 11 2002:
    How to convert your Daewoo DQD-2100D player into a multi-region compatible machine
    Press 0-5-2-0
    Press cursor: up-down-left-right
    Click region free
    Region code hack posted by Daffy Duck, February 21 2003:
    Turn on player. Make sure there is no DVD in the tray.
    Then press 7 - 7 - play to enter the menu for the regional code entry. example: 1 for U.S. or 9 for all regions.
    Press setup to leave the menu...
    Region code or Macrovision hack posted by angel_bleu, January 28 2002:
    1) Turn DVD on.
    2) Open the tray, do not put a disc inside
    3) Press SETUP on the remote control
    4) From the menu, choose PARENTAL CONTROL with the arrows on the remote. Once is highlighted press OK on the remote.
    5) On the PARENTAL CONTROL menu, choose DEFAULTS, then highlight RESET (do not press OK at this point)
    6) While RESET is highlighted, enter with the remote control the following codes:
    5270 for Region free
    5271 for Region 1 (US & Canada)
    5274 for Region 4 (Mexico, etc)
    7) After entering the code you want, if it was properly entered you will see the words:
    REGION:FREE (if you chose code 5270)
    REGION:1 (code 5271)
    Then Press OK on the remote.
    9) You will then see a PASSWORD VERIFY screen, and enter 0000 , end then press OK
    10) Finally, press SETUP to exit.
    But Macrovision is still on and dont know how to turn it off
