Need good wireless pc card 'N'....???
Discussion in 'Desktop & Laptop Computers Forum' started by rude1978, Jun 13, 2008.
  1. rude1978
    rude1978
    Nov 5, 2007
    144
    16
    I have a new pc coming monday.
    I need to get an internal pc card and I was told that I should get one which ends in 'n' or something to do with 'n' lol.
    Its the new version and is faster than 'g'...?
    Anyways is this true and wheres a good place to get one from?
    many thanks...
  2. Andy98765
    Andy98765
    Feb 15, 2006
    10,438
    2
    +1,347
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,469
    Rainham Essex
    +2,479
    Agree with the above post. A wireless N card will only offer a benefit to transfer speeds if the router is also Wireless N. If either card or router are only Wireless G then the transfer will be throttled to Wireless G speeds.
    Wireless N is a new standard and at the moment works out expensive. I would only get Wireless N equipment if you know you need the extra speed and coverage it offers. If unsure then the chances are that Wireless G is enough for you.
    Mark.
  4. rude1978
    rude1978
    Nov 5, 2007
    144
    16
    Im not sure but I think mines a 'g'
    It is one that virgin broadband sent me.
    Is it worth upgrading to 'n' ? would I get alot better speeds?
    thanks
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,469
    Rainham Essex
    +2,479
    What are you trying to do over the wireless network? If it is just web surfing and simple things like that then G is plenty good enough. Multiplayer gaming 'might' make use of the extra speed.
    Mark.
  6. rude1978
    rude1978
    Nov 5, 2007
    144
    16
    Having done some research and thanks to you guys on here I have found out more about this and going by my needs I am going to go for this:
    http://www.pcworld.co.uk/martprd/product/seo/018568
    and also to go with it :
    http://www.pcworld.co.uk/martprd/st...duct&fm=13&sm=1&tm=3&sku=725884&category_oid=
  7. rude1978
    rude1978
    Nov 5, 2007
    144
    16
    Scratch that, have read bad reviews on that router :(
    I think D-Link DIR-655 is the way to go.
  8. Gow87
    Gow87
    Dec 18, 2007
    244
    +23
    the dlinks are a good bet and you can get them with a usb dongle quite cheap at the moment!
  9. rude1978
    rude1978
    Nov 5, 2007
    144
    16
    I was thinking of getting an internal pc card as I heard the usb take up quite alot of the comps memory?
  10. EndlessWaves
    EndlessWaves
    Apr 7, 2008
    13,394
    Norfolk
    +2,406
    If that was the case a lot fewer things would be using USB.
    If the PC is a standard desktop and accepts PCI or PCI-E cards that may be a better way to go though.
  11. rude1978
    rude1978
    Nov 5, 2007
    144
    16
    What are the advantages?
    I was going to get my d-link router from pcworld but they ony have a usb network card to go with it, so im now opting to get both the router and a pci card from dabs.
