Need freeview box for top up TV
Discussion in 'Freeview & YouView' started by moshchops, Jun 9, 2005.
  1. moshchops
    moshchops
    Jun 7, 2005
    15
    Can anyone point me in the direction for a freeview box which accepts a top up tv card.
    Cheapest i've found is around £70.00
    thanks
  2. Shwing
    Shwing
    Feb 1, 2005
    128
    +9
  3. Sami
    Sami
    Jan 15, 2004
    2,209
    Forest Hill, London
    +83
  4. HarryAlffa
    HarryAlffa
    Jan 6, 2005
    61
    I'm having trouble with my Thomson DTI 2300 and have been looking to take it back to the shop for a refund and get another.
    However the BT iPlayer+ for Freeview TV does not seem to be able to control a VCR to record programs on it's timer. I'm on the phone to BT just now 0800 328 9654 (8am-8pm Mon-Sat) ....
    They've put me through to the technical helpline 0870 241 8636 ...
    Excellent, it does control your VCR via scart on timer events. I'm ordering one right now!
    It's on a Special Introductory Offer of £79.99 until 1st July, after that another tenner.
    The review, which was made available by Sami, mentions a "phantom PVR for £30". It turns out that this is only for controling a VCR (via Infrared) which cannot be controlled over the VCR scart.
    I couldn't find a "phantom PVR" on the BT Shop site but the technical helpline knew what it was.
    RadioandTelly.co.uk review of this box.
  5. BillyBits
    BillyBits
    If you do consider the BT iPlayer+ (which I would recommend) a cheaper option is to buy the BT iPlayer from http://www.telephonesonline.co.uk for £49.99 and upgrade the firmware to the + (easy to do via dialup or broadband). The kit comes with wireless remote & wireless keyboard and gives you lots of extra features. This saves you over £50.
    Only one downside for the iPlayer is the lack of RF output.
    You can also get a compatible USB WiFi adapter for an extra £15.
    Without doubt the most feature ridden Freeview receivers around.
    Regards,
    BillyBits
  6. moshchops
    moshchops
    Jun 7, 2005
    15
    Does this model take the top up TV card?
  7. BillyBits
    BillyBits
    Yes. The BT version of the iPlayer/+ has the TUTV cam built into the software..
    You only need the TUTV card for the extra channels.
    For the netgem versions of the iPlayer you need to buy a CAM and a card.
    Regards,
    BillyBits
  8. moshchops
    moshchops
    Jun 7, 2005
    15
    Hi all, thanks for you feedback, went for the BT version.
    What a piece of kit, for the same money what I would pay for a standard box from a high street store I can do so much more, got my broadband connection running through it and the web pages are really good on my 27" LCD TV.
  9. HarryAlffa
    HarryAlffa
    Jan 6, 2005
    61
    Well actually it doesn't. :mad:
    It's supposed to, I phoned BT shop and got them to send me another. That doesn't work either.
