need fast help !! I am missing the snooker.
Discussion in 'Satellite TV, Sky TV & FreeSat' started by jamieuk23, Apr 16, 2005.
  1. jamieuk23
    jamieuk23
    Oct 25, 2004
    2,159
    +27
    Hi I have a freeview box and I have pressed the red button to go interactive >> then I click "Live snooker". but it just keeps on saying loading........
    and doesnt connect to anything. been doing this since I bought it, do I need to hook the freeview box up 2 a phone line or something.
    any advice >>>???
  2. lostinspace
    lostinspace
    Apr 30, 2004
    1,579
    +274
    You should be diverted to station 701 straight away,so try keying that in.If it works you can use the up/down button to switch between tables.I'm not an expert but it may work.Also try re-installing the box to ensure the channel list is up to date.
    Good luck!
  3. gphys
    gphys
    lucky you, try watching paint dry, much more exciting !
  4. mc64
    mc64
    What channel is "Watching Paint Dry" on? Think my freeview box might be faulty as I can't find it!
