Need extra HDMI 2 for my Sky box
lilibet
Have the PANASONIC 58DX750. TV has 4 hdmi sockets, but only 2 are hdmi 2 which put out a 4K signal. They are occupied by my PS5 and XBOX SERIES X. I also have a Sky Q box in hdmi 3 socket, but this is only displaying in 1080p. As I pay for 4K Sky, is there a splitter that I could plug into hdmi 1 or 2, that would allow me to connect the SKY Q to it, so it would display in 4K ?. If it’s possible to do this I’d appreciate any advice on any particular splitter that would work.
mikej
What you need is a '2-in, 1-out' HDMI splitter.
Try searching Google or Amazon for '2 in 1 out HDMI 4K' and you'll get plenty of options. Just make sure it supports the resolution and refresh rates you require and bear in mind that some may need to be physically switched with a button on the unit (this is sometimes reflected in the use of the terms 'splitter' or 'switch', but not always).
