I have just had a bit of a change around with my set up that means I will no longer be using my PS3 for Blu-Ray, but will be using it for TV via PlayTV.
I have the PS3 connected to the amp by HDMI, but this sends a signal to which the amp recognises as 'Multi Ch In' and proceeds to output in stereo only.
Is there a way to get the PS3 to pass the audio to the amp so it can convert it to DPLII? I have an optical connection as well if that is any use.
