Need discrete codes for Sony Freeview
Discussion in 'Home Cinema Control & Remote Controls' started by NicH, Jan 1, 2004.
  1. NicH
    NicH
    I am looking for discrete codes (on/off) or a sony freeview box VTXD800. I've looked on Remote central, but no joy. Can anyone help please...
    Nic
  2. wizbongre
    wizbongre
    Jun 24, 2003
    592
    Liverpool, Merseyside
    +63
    I too am looking for these...
    I'm also curious as to how the discrete codes come into being... Does someone sit down and program random hex codes to see what they do?!:p
  3. Digiman
    Digiman
    Dec 17, 2003
    367
    +17
    NicH / wizbongre
    Did you manage to find discrete codes or a workaround?
    Regards
  4. Swinnydon
    Swinnydon
    Dec 11, 2002
    342
    16
    Cambridge
    any luck?
    I'm after these as well!
  5. The Robman
    The Robman
    None of you have mentioned what format you want the codes in. The OBCs for discrete on and off are usually 46 and 47 for Sony devices, so I would suggest trying those.
  6. Swinnydon
    Swinnydon
    Dec 11, 2002
    342
    16
    Cambridge
    I'm actually looking for the whole ccf for the remote for a pronto940
  7. The Robman
    The Robman
    Do you not have the original remote? If you do, you can create the CCF yourself by learning the signals from the original remote. If you're just missing the discrete codes, I could probably generate then in Pronto hex format.
  8. Swinnydon
    Swinnydon
    Dec 11, 2002
    342
    16
    Cambridge
    Cheers Rob,
    Yeah I have the original remote, I'm just being lazy and was hoping that I could find a ccf for the whole remote to save me the tedious job of getting the Pronto to learn them all!
    chris
  9. The Robman
    The Robman
    How many buttons are there on the original remote, about 30 or so? Let's say that it takes 10 seconds per button, that means it should take about 5 minutes to get the whole thing captured.
    If you just don't like learning, you could use the MakeHex program to generate the Pronto hex for you, you can get all the code info here:
    http://www.hifi-remote.com/sony/Sony_idtv.htm
    You can get MakeHex from Remote Central
    If you do this, remember to include OBCs 46 and 47 as these are possibly the discrete on and off codes.
  10. The Robman
    The Robman
    OK, don't say I don't do anything for ya. Attached is a file, created by MakeHex, that includes all the Pronto hex for the Sony Freeview.
    For those that are just looking for the discrete codes, try these...
    Function: 46: discrete on
    0000 0068 0000 0015 0060 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0018 0018 0018 0018 0018 01DE
    Function: 47: discrete off
    0000 0068 0000 0015 0060 0018 0030 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0018 0018 0018 0018 0018 01C6
  11. Swinnydon
    Swinnydon
    Dec 11, 2002
    342
    16
    Cambridge
    Brilliant! Thanks for that Rob. I was going to do the learning this weekend but looks like I won't have to now :) I'll try the codes out on the weekend instead I think :clap:
  12. The Robman
    The Robman
    So, has anybody tried the discretes to see if they work?
  13. The Robman
    The Robman
    Anyone?
  14. Swinnydon
    Swinnydon
    Dec 11, 2002
    342
    16
    Cambridge
    Not had a chance yet I'm afraid since I haven't worked out how to get ProntoEdit to work when my Pronto is connected on a port other than port1
  15. Swinnydon
    Swinnydon
    Dec 11, 2002
    342
    16
    Cambridge
    Oh, and that's a problem since I've been away on business for the last couple of days so haven't been able to connect it to one of the desktops at work :-(
  16. Rob100
    Rob100
    Nov 3, 2002
    3,482
    +227
    Those codes didn't work for my VTX-D800U Freeview box.
    I have never looked at this before as I don't use my Pronto in the room where I have this Freeview box, but I thought I'd give it a go anyway (just out of curiosity)....
    Anyway after a quick play with IR Tool (and with the knowledge shared by "The Robman" that Sony use 46/47 for these codes), the correct codes are as below:
    ON:
    0000 0067 0000 0015 0061 0018 0018 0018 0031 0018 0031 0018 0031 0018 0018 0018 0031 0018 0018 0018 0031 0018 0031 0018 0031 0018 0018 0018 0031 0018 0031 0018 0018 0018 0031 0018 0031 0018 0018 0018 0018 0018 0018 0018 0018 01f3
    OFF:
    0000 0067 0000 0015 0061 0018 0031 0018 0031 0018 0031 0018 0031 0018 0018 0018 0031 0018 0018 0018 0031 0018 0031 0018 0031 0018 0018 0018 0031 0018 0031 0018 0018 0018 0031 0018 0031 0018 0018 0018 0018 0018 0018 0018 0018 01f3
    Hope this works for others.... Rob :thumbsup:
  17. The Robman
    The Robman
    Thanks for that Rob, I had indeed made a typo when I generated the code, I was using device code 23.18 rather than 23.13. I have just re-created the file and replaced the attachment in my earlier post.
