Quantcast
Need Direction Please
PannTher
Good day!
I have read the following thread: http://www.avforums.com/forums/subwoofers-tactile-transducers/955704-rel-b1-vs-svs-pc13-pb13-problem-6.html
and found it very informative. Thanks to those who contributed.
My question is, should I purchase an SVS 13-PLUS, SVS 12NSD, Rythmik F12SE or used REL R-505 for a medium sized room. It will be paired with CM8s, CMC2, and CM1s.
I am looking for a musical sub, but will be using it for HT as well.
I will be adding a second identical sub down the road (or right away).
I know that RELs are usually a lot more money, but if I get a used one, would it be better value than a new SVS or Rythmik?
I really appreciate your help on this.
Thanks in advance.
