Need Component Output CONVERTER to DVI Input
Discussion in 'Cables & Switches' started by MaverickDrummer, Mar 22, 2005.
  1. MaverickDrummer
    I'm looking at dropping on a Hyundai ImageQuest L90D+ 19" LCD Monitor and I would like to play my xbox and use this monitor as a spare TV on my home cinema system.
    Therefore I need to plug Component cables into it, but it takes Either DVI or VGA inputs.
    I know that there are Component to VGA (DB15) adaptors but I wanted to know if I can convert component to DVI => that should give the best picture right?
    Any suggestions / advice?
    PS. I'm in the UK and I'm trying to get HD on my Xbox and it's not working at all in the projector system (NEC HT1000) using the MS HDTV cables with component out and a modded xbox outputting NTSC... so I wondered if THIS would be the way...
