Need clarification on DVD R issues Pan e55
Discussion in 'Blu-ray & DVD Players & Recorders' started by robertjp, Dec 18, 2004.
  1. robertjp
    robertjp
    Greetings,
    Is it true that you can not play a dvd-ram back on a reular dvd player or computer with dvd drive? Mine wont.
    Also is it true with the Panasonic e55 you can create chapters but can not name them? Are all dvd recorders like this? Panasonic told me you can not name chapters but I find this hard to believe. Does anypne know different? Thanks in advance and happy holidays. BP
  2. jeff9999
    jeff9999
    Dec 13, 2004
    28
    Answer to question1. No, RAM discs will not play back on normal DVD player. Record onto a DVD-R instead.
  3. Archie Fax
    Archie Fax
    Nov 23, 2003
    233
    Kent
    +10
    Regular dvd player? Panasonic make regular dvd players which play ram discs no probs.
  4. hammy
    hammy
    Feb 10, 2004
    26
    3
    I've got 2 normal/regular Panasonic dvd players S35 & S27 and both play Ram discs no problem, you can get the S27 for under £80 if you shop around.
    As for PC, LG multi drives and some of their dvd-rom drives handle Ram discs no problem, some toshiba drives wll also and of course Panasonic drives will. I think the Pioneer 108 can read RAM discs.
    Hammy
  5. secretgunner
    secretgunner
    I'm looking to get an e55 and was wondering whether you an record onto a format of disc that would play on any DVD player? If so, what is the advantage of this DVD-ram discs?
  6. CHR1S
    CHR1S
    DVD-RAM plays on my Samsung DVD-ROM drive no probs
  7. johnjackthom
    johnjackthom
    Sep 20, 2001
    707
    46
    Northumberland
    +236
    The E55 will record on DVD-R which will play on the vast majority of DVD players.
    RAM disks are fairly robust and can be re-used many times. They are also available in caddies making them reasonably kid-proof. :)
    The drawback is that not many players can handle RAM.
