Need cheap but excellent optical cable
clockworks
craig777 said:
Check out ebay... loads of 'em on there.
Or this looks like a good deal... http://www.audiovisualonline.co.uk/...5/profigold-pgd561-optical-cable/display.html
They lost me when they said that the tip was gold plated for optimal signal transfer. Utter tosh - how can gold plating help transfer an optical signal?
Don't bother spending more than a fiver on an optical cable. Analogue interconnects do affect sound quality, so it's worth buying decent ones. For digital, it makes no difference to the sound - it either works, or it doesn't (over short distances).
HiFiRuss71
I quite agree about the merits of digital cables. But I will say that the Profigold is a good, tight fit. That's all there is to worry about IMHO.
Russell
John
My £5 maxview ones I bought from B&Q 4 years ago are still going strong
John
Nic Rhodes
Russell
I think Russel has this right, the important bit is to get tight fit and a fibre that transmits the information well. I wouldn't look at the cheapest optical cable you can get, but pay a few ££s extra and get a well built one, the Profile one here are a good example. It is not expensive to do it right and is generally worth it in the long run.
pjclark1
Almost anything works, I usually pay about £1.50 for a TOSlink cable. When I need a longer cable I just tape two together with a lolly stick and some sellotape like this.
They work perfectly, as usual.
PS If you think your cable is a bit loose, bluetack will do the trick ....... why pay more?
Nic Rhodes
The 3m cable talk one I have is 'too heavy' and produces undue strain on the sockets preventing the link working :) I think it is the gold plating. Perhaps sellotape will make it work better :)
