Need built in Book shelves.
Discussion in 'General Chat' started by shahedz, Oct 23, 2005.
  1. shahedz
    shahedz
    Apr 26, 2005
    11,116
    +2,045
    need some built in book cases and cupboards , whent on www.jali.co.uk , something like that would be ideal but , i dont have the diy skills to really put it togther properly or dont want to have to paint it,also four case end up close to £1200 which i think is really expensive for MDF.
    can anyone recommend someone they have used that works in London, not MFI i had huge problems with them
    cheers!
  2. shahedz
    shahedz
    Apr 26, 2005
    11,116
    +2,045
    anyone?
  3. John
    John
    Dec 13, 2002
    11,716
    +3,411
    Dare I say the Billy range form Ikea. (i think thats what there called )
    J
  4. John
    John
    Dec 13, 2002
    11,716
    +3,411
    here's a link
    J
  5. shahedz
    shahedz
    Apr 26, 2005
    11,116
    +2,045
    cheers for the link, but the alcoves are 94 & 95 cm wide. so that wouldnt fit also i have 2 more spaces which are 45 cm wide, and to find shelves that fit exact is impossible. so i need to go the tailor made option, which is pretty tough!
  6. John
    John
    Dec 13, 2002
    11,716
    +3,411
    Fair enough , single billy cabs are 40cm & 80cm .
    Maybe a trip to B&Q is in order
    Good luck
    John
  7. Dr Diversity
    Dr Diversity
    If you don't buy built in books then you won't need built in book shelves. Perhaps use a library in future
