Need av receiver and some help, MA BX5 acquired already
al4x
Hi, need some help with my new plan
Right now I have my Htpc passing through video and audio to my 3D av receiver and this then being sent to my 5.1 speakers and tv by hdmi
My current setup is
Htpc gpu with 1. 4a hdmi
Yamaha v371 which is bottom of the pile
Boston acoustics soundware xs
I know Ineed to uupgrade the amp, would prefer to stick to Yamahabut not eessential
Problem is I will probably want to keep my 5.1 current set until I have a 5.1 set based around bx5 and whatever I get in future (I'm guessing it would be silly to run the bx5s as fronts in a 5.1 with the speakers I have as rears!)
How do I proceed? Do I need 2 amps? Or would the receiver I'mgoing to get be able to run bbothsseparately? I really don't know how to proceed.
PSM1
You have a few options considering you have all the equipment already.
There would be no issue running the BX5s with the BA as rears so no real worries there. The thing that may not sound good is the BA centre with the BX5s but you could run a 4.1 system i.e. remove the BA centre and let the BX5s create a phantom centre. You could try it with and without the centre and see which you prefer until you can afford the proper BX centre. Your current receiver will not get the best from the BX5s but should power them OK.
You could get a speaker switch so could connect the BA and BX speakers to your front L/R outputs and then switch between the speakers depending if you want to listen to stereo sources or a 5.1 source.
al4x
Originally I was planning to upgrade the receiver first then centre speaker, BA centre really isn't up to the job
What route would you go down? I didn't think my receiver would handle the bx5s at all
Thanks for your response
PSM1
Although the BX5s are floorstanders they are not a particularly difficult speaker to drive so your current receiver will be fine powering them. If will not get the best out of them (although you will probably be getting the best from the receiver!!!) but it should still sound OK. I would personally get the centre and then upgrade the receiver.
al4x
OK ill go with that, I kind of regret getting the BA system, although it'sa ok for movies, it definitelylacks in for music and the centre channel sounds hollow and crowded , but it's my first time I had anything more than a cheapo stereo. I have the funds to get either the centre or upgrade receiver immediately so might be on the look out for the it
Thanks for putting the time in to reply, I really appreciate it
PSM1
No probs, get the centre and then save up for a good receiver. You would be really be looking at something like the Denon 1913 or Onkyo 616 to power the BX to their full potential.
al4x
I'll have a proper look into avs, will need to learn a bit too, I don't really understand the real differences between models beyond the numbers
