need Astra2D transponder info
Discussion in 'Satellite TV, Sky TV & FreeSat' started by C-M, Aug 29, 2005.
  1. C-M
    C-M
    Jun 7, 2005
    52
    I need to test my skystar2 card in linux to see if its setup right. The only way i can think of doing it, being as i've received no help, is to connect it to my sky mini dish and scan for channels. in order to scan i must first entre the transponder details in the following format:
    # Astra 19.2E SDT info service transponder
    # freq pol sr fec
    S 12551500 V 22000000 5/6
    # EUTELSAT SkyPlex, Hotbird 13E
    # freq pol sr fec
    S 12539000 H 27500000 3/4
    Obviously the sky dish is pointed at astra2d 28.2E Does any have the transponder infomation for that satellite?
    While on the topic what is a transponder?
  2. Lakeuk
    Lakeuk
    Jul 20, 2003
    247
    Kendal
    +20
  3. Heinz
    Heinz
    Aug 4, 2005
    408
    Earle Colne, Colchester
    +15
    http://www.onelook.com/?w=transponder&ls=a
  4. C-M
    C-M
    Jun 7, 2005
    52
    cheers. Yeah i know about the lyngsat site, still i haven't found anything to do with transponders on the site at all.
    EDIT: if the transponders are the numbers down the side to the left of a group of channels then they do not match the format i need to use. for example the first number is only 5 digits not eight as in the examples in my initial post.
  5. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
  6. Heinz
    Heinz
    Aug 4, 2005
    408
    +15
    Same with the SR [Serial Rate] (22000 = 22000000)
  7. C-M
    C-M
    Jun 7, 2005
    52
    s 10714000 H 22000000 5/6 definately does not work, it doesn't even hessitate in throwing up an error. They haven't added 3 "000" onto the astra satellite, it ends in 500.
