Need another Freesat Box - which one?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by bwblackett, Jan 28, 2014.
Tags:
  1. bwblackett
    bwblackett
    May 7, 2010
    137
    Blackpool
    +4
    I have a Foxsat, with Raydons software installed working well in the lounge, and want a Freesat box for the bedroom.
    I just need a basic box, not bothered about recording or Youview particularly, but would want it to be able to play things I've recorded on the Foxsat box in the lounge.
    Is there such a box?
  2. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,618
    Redditch
    +4,208
    It depends on whether or not you have Nowsters patch installed. If so the HB1000S is probably your best bet.
  3. bwblackett
    bwblackett
    May 7, 2010
    137
    Blackpool
    +4
    Thanks for the reply Graham, Nowster patch is installed.
    So am I right in thinking the HB1000S has some kind of DLNA player built in?
  4. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,618
    Redditch
    +4,208
    Yes it has a DLNA server (essentially identical to the HDR1000/1010s). Only a single tuner but it will record to a usb hard drive if you wish to add one. With luck it may well get a client eventually
  5. mickeyboy
    mickeyboy
    Jun 9, 2010
    84
    +4
    Don't you mean it's got a DLNA client? I doubt the HB box will ever get DLNA server capability.
  6. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,618
    Redditch
    +4,208
    Long day, yes it's a client. However at the launch of the HDR1000S a server was promised in a future update to match the Foxsat-hdr. It would seem certain that the HB1000s will be similar.
    The OP wanted to watch recordings made on a Foxsat-hdr on a separate freesat box. Apart from an issue with HD recordings with an AD audio track the HB1000s should do the job.
  7. Gezmondo
    Gezmondo
    Mar 20, 2004
    359
    Harrogate
    You can have my foxsat hdr box for
  8. mickeyboy
    mickeyboy
    Jun 9, 2010
    84
    +4
    I'm really don't think the HB will ever get DLNA server capability, although I'm just basing this on the fact that Humax never gave it to the HD FoxT2 either.
    A bit off topic though, sorry.
  9. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,618
    Redditch
    +4,208
    The HDR FOX T2 has both server and client capability. So far every upgrade to the G2 pvr range software has been matched for the HB1000s. Clearly under the skin they are near identical apart from the single tuner and no built in Hard Disk.
  10. mickeyboy
    mickeyboy
    Jun 9, 2010
    84
    +4
    I know the HDR Fox T2 has client and server DLNA, but I specifically mentioned the HD Fox T2, which despite the similarities with the HDR still only has a DLNA client.
    I would love the HB1000S to get the DLNA server upgrade along with the HDR, but if Humax keeps things similar as the did with the HDR/HD FoxT2, then I don't expect it.
  11. TJT1
    TJT1
    Jul 29, 2011
    4,825
    East Sussex, UK
    +1,139
    Why would it have a server when there's nothing stored on it to serve?
  12. REPASSAC
    REPASSAC
    Jan 11, 2011
    2,990
    Perchede 32460
    +456
    If you add a USB disk there is. However I think I remember seeing a post by a reliable source that said it would not be added to this unit.
