Need advise on Wall Mounting a Toshiba WL56 32 inch
Romero
Hi Folks,
have searched this forum, searched the Tosh site and googled it, but I can't find a answer on what kind of wall mount I need for this, there are four screw holes on the back spaced 330H x 610L, this doesn't seem to be standard for normal brackets, so just wondering what folks are using?
Romero
Romero
Hey thanks for the advise could u check the back of your set to tell me is it mounted using the screws in the four corners as asked above?
Romero ;)
