Need advice
Lsj
Hi Folks, new guy here, just needing some assistance.
I am putting in some infrastructure for a work building. Basically it is an AMFM antenna on a second story roof, as well as a Sirius Antenna, to a small lab on the ground floor.
The lab is currently not getting ANY AM/FM or sat signal at all, and I have several radios that require getting these signals in the lab.
What I have done so far:
Pole mounted the antennas and from there, ran 300 feet of 75 Ohm RG-6 into the room I need it to go.
The AMFM antenna:
Amazon product
The Sirius XM antenna:
So, now that the RG6 is down in the room for both antennas, I tried connecting this antenna on the other end of the coax (using a coax coupler since both ends are female) to the AM/FM cable.
Amazon product
When I try turning on a small radio in the lab and tuning, I get no signal. My questions:
What am I missing here? Do I need a repeater or amplifier since my cables are 300 feet long? Do you have any suggestions on which to buy if that is the case?
Is this even possible or do i need to direct connect my radios with a splitter?
What about Sirius? Will another antenna like the one on the roof provide signal?
Please do help if possible.
Lsj
It should be noted here as well that I do not want to direct connect the radios in my lab if i can help it. I would like to simply have them be able to get radio signal from the outside antenna. So I guess I just need to know what is capable of that.
