Need advice
Discussion in 'LCD & LED LCD TVs' started by killer10971, Dec 29, 2004.
  1. killer10971
    killer10971
    Dec 29, 2004
    1,028
    +29
    hi all
    i have just ordered a philips 37pf9986 and am looking at wall mounting.
    The wall is a plasterboard covered stud wall (partition) has anyone attached to this type of wall (27Kg screen).
    i was looking at fixing a square of wood externally through the plaster board to to the internal studs/joists and the fix the wall mount to that , or should i just use a table top stand to be on the safe side
    many thanks all
