Need advice : Sanyo Z2 scaling
Discussion in 'Projectors, Screens & Video Processors' started by edgler vess, Nov 13, 2004.
  1. edgler vess
    edgler vess
    Nov 23, 2002
    91
    I´m a newbie ... so ...
    Can anyone clarify the following:
    I have a Sanyo PLV-Z2 projector and my source is the Yamakawa Dvd player which is DVI equipped.
    I have two options ... I suppose:
    1)
    I've got the Yamakawa set to output 720p.
    I suppose that the player is doing all deinterlacing/scaling.
    The projector accepts the signal and has nothing to do with conversions.
    2)
    I set the Yamakawa to output 480i/576i and let the Z2 do all the deinterlacing/scaling.
    Are these options correct ?
    and
    Which is the better option ?
    Thnaks in advance
  2. ROne
    ROne
    Dec 21, 2000
    779
    +7
    All things being equal - hopefully the DVD player will do a better job of scaling the picture than the projector. So the former.
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    IIRC the Yamakawa was in the same group as my Momitsu, Bravo D1s etc., and my Momitsu was excellent with the Z2 using the V880's scaler ... so use the DVD to deinterlace/scale. :smashin:
  4. inzaman
    inzaman
    Dec 16, 2002
    7,888
    Derby
    +941
    I havent used that dvd player but i am pretty sure, as it has been said above, that the scaler will be better than the Z2s because imo the Z2 scaler is pretty poor.
