Need Advice Please
Discussion in 'Satellite TV, Sky TV & FreeSat' started by penfolduk2005, Mar 24, 2006.
  1. penfolduk2005
    penfolduk2005
    i have a HYUNDIA HPT4240 plasma i can get my xbox 360 running games at full 1080i (though component sockets) on it will i be able to use it for SKYHD
    plasma has sockets DVI(P), RGB(P), X2 COMPONENT (Y,PB,PR)
    please help desperate to know if i can get HD
    thanx
    penfolduk
    :lease:
  2. The_Munter
    The_Munter
    Feb 23, 2005
    131
    london
    Yes, you'll need a DVI > HDMI converter socket thing
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    If the component connection accepts 720p/50 and 1080i/60, you can connect it via component, but Sky have stated that some material may not be viewable via component.
  4. penfolduk2005
    penfolduk2005
    now not too sure :(
  5. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Then wait a while:)
    SKY are pushing the free install to make sure the launch makes a big splash and it's highly unlikely that that sort of offer will vanish in the longer term.
    Your plasma is SD resolution?
    If so then you will still see some benefit from HD sources but you won't be getting the full impact, a lot of money to pay for SKY HD without a HD panel, but not going to say it would be a mistake:)
