need advice please for a new LCD for kitchen...
Discussion in 'LCD & LED LCD TVs Forum' started by fastersound, Jan 15, 2008.
Tags:
  1. fastersound
    fastersound
    Aug 22, 2007
    hello,
    was wondering if anyone can help find a suitable tv..needs to be digital/freeview, and also can't exceed 39cm height (including stand). a reliable tv/brand preferably..with decent enough sound too etc
    it seems the 19" tvs are a few cm too high, there doesnt appear to be many 17" tvs at all..so it looks like its going to have to be a 15" tele.
    the only ones i have been able to find thus far are:
    Hitachi:
    http://www.dixons.co.uk/martprd/sto...m=null&tm=null&sku=154345&category_oid=-21226
    Wharfedale:
    http://www.argos.co.uk/static/Produ...televisions>FC$Screen+Size+(inches)=15.15.htm
    does anyone know if these are any good? or are there better tvs out there that fit the criteria?
    also, where is good to order from?
    thanks very much!
  2. fastersound
    fastersound
    Aug 22, 2007
  3. fastersound
    fastersound
    Aug 22, 2007
  4. fastersound
    fastersound
    Aug 22, 2007
  5. Jazzy639
    Jazzy639
    Dec 28, 2006
    582
    +20
  6. fastersound
    fastersound
    Aug 22, 2007
    thanks for the reply jazzy...ive also just found that a lot of 19" tvs are the same height as the 15" ones...so its back to square one for the moment!
    so far, im liking the look of:
    SAMSUNG
    http://www.argos.co.uk/static/Product/partNumber/5290963/Trail/searchtext%3ESAMSUNG.htm
    and
    LG
    http://www.argos.co.uk/static/Product/partNumber/5293173/Trail/C%24cip%3D1500011405.Sound%2Band%2Bvision%3EC%24cip%3D1500011489.Televisions%3EC%24Brands%3DLG.LG.htm
    these seem to have much higher contrast ratios..
    the tallest, including the stand, is the LG at 39.66cm...which just squeezes under the unit..so can't really go any taller than this...
    thanks again
    Louise
  7. IanW1977
    IanW1977
    Dec 30, 2002
    4,580
    West Midlands
    +484
    Is it worth an extra £100 for Freeview ?
    Surely you can buy even one of those Scart Digital receivers ?
