Need advice on wall mount for Acer AL2671W 26inch ,
Discussion in 'Home Cinema Buying & Building' started by JET_PILOT, May 3, 2005.
  1. JET_PILOT
    JET_PILOT
    Hi all
    Can anyone advise me what was mount to get for an Acer AL2671W 26inch ?
    not too sure on the fixing plate size as the TV is being delivered later in the week.
    Thanks in advance
    JET
  2. Vallyboy
    Vallyboy
    You need a 100mm Vesa mount.
    A simple one is here but please note that this link is for the 75MM one as the 100mm does not link, due to no stock but available in a few days so they say.
    If you need a swivel twist type do a google search or whatever.
