my 21 inch CRT monitor has 28 dpi and I am happy with the dot pitch but how can get dot pitch info on tv screens ?
I've been told if I get a dvi - HDMI cable my PC's display will be displayed in full HD which means dot pitch will be as good as PC monitor as they all HD.
Unless you're got it hooked up to a vintage PC in glorious 480x320 I suspect that's a .28" dot pitch rather than 28dpi.
Although dot pitch was important for CRTs these days it's just another way of expressing resolution and size. Basically:
Resolution / size = dot pitch.
(size * dot pitch = resolution and so on)
HD is the resolution 1920x1080 so the dot pitch will vary depending on the size of the screen.
What range of brightness and contrast figures would be good.
First, ignore the advertised contrast figures. The Advertising Standards Agency has been sleeping on the job again and as a result they've been blown out of all proportion and are completely useless.
I'm not up on TV contrasts but most monitors have tested contrast around 1000:1 with some of the new VA panels achieving closer to 3000:1.
Brightness depends on where you're using it and what you're using it for, Unless it's going to get lots of use in very bright summer sunlight or a dark room then maximum and minimum brightnesses aren't going to be much of a concern.
At around £400 you're looking at a 1920x1200/1920x1080 23-24" good quality monitor, you're not going to get one of the bigger, higher resolution ones at that price. If you're considering a 40" TV then will a 24" monitor be close enough to read (assuming you need to read text on it) and most computer things are sized in pixels?
