Need advice on my rears
kroc_kroc
I have MAGR60 fronts and a MAGR Centre. Ideally I would like to get some GR FX for the rears but I can't find any suppielr who has them in stock. My fronts and centre are a cherry finsih so if I go for MA I would like the same finish. I was wandering if someone could recommend something which would fit in nicely with what I have.
PS
My amp is a Yamaha DSP Z9
Knyght_byte
why not go for the new GSFX's.....they wont make too much difference when it comes to rears over the GRFX's except they have more ability by being full monopole as well as dipole...w00t!
not sure about finishes tho.....however iirc the GSFX's only had the caps in colour, the grill or actual speaker was still black....
kroc_kroc
Cheers for the quick response KB
Someone has suggested to get another 2 centres and use them as rears???
Apparently it won't have the full 360 panaoramic sound but the actual sound quality is supposed to be amazing.
Knyght_byte
hmm...well, you could use 2 more centres, but that puts a serious load on your amp, twin mid/bass drivers plus tweeter as rears?......i'd be more inclined to consider a pair of GR/S10's or GR/SFX's....
edit: mind you, remembering what amp you got, i guess its worth a try...lol
