New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
right guys, any advice ?("keep it clean" in my best windsor davies sergeant voice)
are there any specific PS3 brackets I can buy ?
(I do know not to mount the RHS of my PS3 too close to a corner)
Not sure if there is one specifically for the ps3 but if you can get the bottom cover off and drill 4 holes say, then using thick spacers you could possibly mount it on the wall while still leaving room for ventilation. Think it would look pretty good mounted like that.
